Help Set up wizzard
I set up a Google account
Password
I have WiFi network connection
And when I click next is loading and then
It pop up a message saying !!!!!!!setup wizard has stopped!!!
I had the same problem. To log in dont put any info in at first( no wifi, name, ext) , then when you are in thats when you can fill all of it in
( do allow setup wizard)
这个答案有帮助吗?
here is the fix to this problem on the Digiland DL-7006 and may work on others as well. follow steps carefully.
这个答案有帮助吗?
First power off the tablet
Second press and hold volume down and power until the digital screen appears
Third as soon as digiland screen appears press volume up, down, and power repeatedly over and over
Fourth use the volume down to select the Chinese symbol third from bottom with Emm in it
Last wait for tablet to power on, it will take a while. When it powers on skip everything. Do not connect to Wi-Fi or set email or tablet pin, SKIP EVERYTHING
tablet should unlock and you can set it up from settings >accounts *add account
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 32
总计 4,442
6条评论
How do I setup my tablet wizard keeps popping up
由 Letucia Muse 完成的 分享
Hi have yuou been able to set up ur device
由 Jazinae Jamison 完成的 分享
I'm having the same issue. How do you reset back to the factory settings to be able to start all over again
由 nyob 完成的 分享
Have you figured anything out having the same problem
由 Steven York 完成的 分享
Trying to set up the wizard on my tablet and it keeps on saying the wizard has shut down I don't know what to do
由 Shari Wymer 完成的 分享
显示更多的1条评论
