Valve Specs and how to adjustment
I need to know the valve specs for this engine and how to adjust the valves?
@papasmurf1 valve clearance with valve springs installed and piston 1/4in (6mm) past top dead center (check when engine is cold):
Intake.............0.003-0.005 in. (0.08 - 0.13 mm)
Exhaust..........0.005-0.007 in. (0.13 - 0.18 mm)
Valve Clearance Adjustments
Adjust Valve Clearance
Valve clearances should always be adjusted on a cold engine.
1. Remove the valve cover.
2. Rotate the crankshaft in the normal direction until you get to TDC (Top Dead Center) of the compression stroke.
3. Insert a narrow indicator (screwdriver or small rod) into the spark plug hole against the piston to indicate piston movement.
4. While watching the indicator, rotate crankshaft clockwise (CW) past TDC until piston is 0.25 in. (6mm) down from TDC.
This is to prevent the compression release (if equipped) from affecting adjustments.
5. Loosen the jamb nut on the rocker arm.
6. Insert the proper feeler gauge. While moving it back and forth, carefully tighten the adjustment screw until a slight amount of resistance is felt on the feeler gauge
7. Tighten the jamb nut without moving the adjustment screw Fig. 46, 47, 49, 49.
8. Rotate the crankshaft through a few revolutions and recheck the clearance.
这个答案有帮助吗?
Instead of putting a screwdriver in the cylinder, spin the flywheel til the valve your Not Adjusting is at full compression. That will mean the valve you're adjusting is at full rest. Then Adjust.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 184
总计 42,053
1条评论
I always put one valve a full compression like the other guy said been at for 30years never had a problem doing that way, and it saves time.
由 Scott Newton 完成的
