跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
My ps4 fan goes crazy when starting a game then shuts down the ps4
I had to have my HDMI port replaced so I sent it to a repair shop. They fixed the HDMI but whenever I start a game the fan slowly gets louder until it becomes a jet engine then a over heat screen comes up , red lights blink and the ps4 shuts down. What did those idiots who replaced my HDMI do to my ps4. Fan isn't the issue as I can feel the air blowing. Please help, they even charged me for breaking my Playstation.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
it might be possible that they didnt tighten the heat sink clamp tight enough or some thermal pads could be missing from the board
完成的
So I need to disassemble?
完成的
yes but i would take it back to the person that changed the hdmi as its their fault
完成的
I'm just worried that they'll force me to pay them again.
完成的
if you have the the screwdrivers to do it try it yourself, take the top cover of and tighten the 2 clamp screws
完成的
显示更多的2条评论
添加一条评论
4个答案
已选择的解决方案
I see stuff like this all the time at my shop. Sounds like you got lucky and they at least changed the HDMI port correctly...usually that's the part they screw up. Anyway, given that it overheats so quickly it's likely that they didn't take the time to clean the old thermal paste off and put new thermal paste in. There's no way for me to know for sure since I don't have it here to test...just going off of what I've seen a lot of.
It's also possible that the thermal pads are out of place or doubled up. This can cause the motherboard to not sit completely down against the heat sink like it should which would cause it to not make good contact with the thermal paste and heat sink.
I agree that you shouldn't take it back to the place that "fixed" it. Normally I would give a repair shop the benefit of the doubt but it's clear that the people you took it to are crooks. I've got teardown videos and overheating videos on my Youtube channel and there are lots of other good ones out there too so you could probably take it apart yourself but if you're not comfortable with that you may want to send it in for repair.
Hope this helps.
这个答案有帮助吗?
得分 4
5条评论:
Yup! The thermal paste was definetly the problem. I took the ps4 back to the shop and they replaced the thermal paste for free. Perhaps they're not idiots, everyone makes mistakes. Thanks for your help!
完成的
Wow, that's great that they replaced it for free. They definitely should have since they should have done it in the first place but at least they did. For anyone else reading this if you remove the motherboard then you always need to put in new thermal paste.
完成的
Can this just happen randomly? Having same problem but this is the first issue?
完成的
@beastyboii Yes, it can seemingly randomly happen. The heat sink is most likely plugged. Usually, it will happen when you're playing more intense games but as the heat sink gets worse it'll happen more and more.
完成的
my ps4 started doing this after i bought it. it was broken and the power supply needed replacement. so i paid 50 for the new psu. it got here and as i started it up. the fan started getting louder and louder. suprised it didnt levitate. i took it apart and a thermal pad is missing and their is *NO thermal paste at all on the cpu.
完成的
添加一条评论
Replace the thermal paste and check the heat sink.
这个答案有帮助吗?
得分 2
1条评论:
Thermal paste was the problem.
完成的
添加一条评论
@tronicsfix could this happen without the PlayStation being taken apart? I’m having the same problems but ive never had problems with it until now? Could the placement of my PS4 be a problem?
这个答案有帮助吗?
得分 0
1条评论:
Placement can be a problem but doesn't generally cause overheating if the rest of the console is in good condition (unless it's placed in a really closed in area).
完成的
添加一条评论
My PS4 won’t turn on the fan speeds up and shuts down it’s happened twice now and now not coming on at all can anyone help me please
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GloryOrBust 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 101
总计 26,471
