跳转到主内容
Philip Wake-up Light identified by modelnumber HF3500/60.
1 个问题 查看全部
How do I disable the speaker/alarm on a Philips 3500 Wake-up Light?
The worst "feature" of this wake-up light is the inability to turn off the alarm and just use the device as a wake-up light. There doesn't seem to be any videos online that provide clear instructions on how to disable the alarm. One forum suggested drilling a hole through the piezo speaker - if you can find it and avoid damaging the circuit board, which I think I might do.
Is there a better way to go about doing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I ended up just stabbing the center hole and the surrounding 6 holes with the iFixIt screwdriver. It popped the piezo speaker and disabled it with minimal work.
完成的
Kevin Kramer for as long as it worked for you ;-)
完成的
Kevin you're a genius my good sir :)
Did as you, only had a leather needle handy, but it did the job.
完成的
I appreciate Kevin Kramer's suggestion since I watched a few videos that didn't explain the 6 hole approach! I futzed about with a paperclip, but what finally really helped me get the leverage I needed to push out the speaker was a regular ol' thumbtack. I *think* I've gotten it out, it's been quiet during the last three tests even though as I watch it I can hear the phantom beeping (my gosh, that's an annoying sound!). Thank you for posting this.
完成的
添加一条评论
2个答案
最有帮助的答案
Kevin Kramer check on here. Royal PITA but possible. Use an old credit card instead of a screw driver to open it up. Unsolder the speaker or develop a turn off circuit ;-)
这个答案有帮助吗?
得分 2
添加一条评论
I just used a long needle to poke the speaker through the grill until it didn't work/couldn't make a sound anymore.
Be aware if you do this, that you can't get the sound back unless you replace the speaker unit. I'm not planning to do that though. 😂
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Kramer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 48
总计 6,656
