trailer running lights not working at plug on truck
which fuse do i check?
Daleo Kelso this will only work if your truck has the trailer towing package. If it has been wired aftermarket, you'll have to dig a bit for it. For the truck equipped with the package:
Fuse F31 will be for the parking lights on the trailer connector and Fuse F58 is for the trailer connector backup lights.
这个答案有帮助吗?
Check #67 under the hood behind radiator. There is a fuse box there. I had same problem. It's a 20 amp blue 1cmx1cm square style with clear window at top. A simple continuity test will tell if it's bad.
这个答案有帮助吗?
trailer is working good now.
过去 24 小时: 22
过去 7 天: 201
过去 30 天: 1,013
总计 32,165
1条评论
# F 150 which fuse should I check when my trailer light not working
由 Zane Walker Walker 完成的
