The backlight is not working.
My phone just turned off and then when I turned it on it doesn't lit anymore
@ameliadepp could be the backlight in your display or the backlight driver as well. I would start with a new display assembly. Use this guide 三星盖乐世 J1 / J100触摸屏与LCD屏幕的更换 for that, If nothing else it will be your known-good point for further troubleshooting. Use these as your guide for further troubleshooting if it should be necessary
这个答案有帮助吗?
Vertical irradiation the screen with a strong light, if you can see the pictrue, the back light is bad and you need to repalce a new LCD screen. If you cann't anything, the display may broken.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 3,072
