跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone won't turn on after apple logo
Hi there,
I've been trying to repair my iPhone and have a feeling the battery is faulty, I was wondering if someone could supply me with the terminal readings for the battery?
what I mean by it not turning on is that you can boot it up ONLY with it plugged into the wall charger, then when I turn it on the apple logo appears as normal then after say 10-15 seconds the phone switches off, when I unplug the USB as it's showing the apple logo it switches off instantly. My dad reckons there's not enough power to go through it (he's good with technical things) therefore I think I need to replace the battery if the terminals aren't reading and I might need to change the dock connector.
My dad tested the battery and it states the right voltage amount but I think he said that one or two terminals aren't reading, could this be the problem?
Amy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Amy, did you fix this already? Exactly the same problem here....
Thijs
完成的
not as yet, had no replies
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like your dad is right. If your battery has good life (3.7 ish?) then I'd take a look at the dock- clean it thoroughly at USB port, clean no4 connector. If that doesn't work then replace it using the guide on top right of his page
这个答案有帮助吗?
得分 1
12条评论:
Well we managed to find out the problem, the fuse is blown on the board, my dad has jump wired it but we can't find a replacement fuse online. It still only turns on when plugged into the wall but goes to iTunes logo, when plugged into PC to try and get it restored it turns off. so annoying!
完成的
lots of people dont use a fuse.. they just make their own with the finest wire they can find, bit of solder and off you go...
完成的
Yeah he tried that but the same problem exists D:
完成的
If you already did as pollytintop suggested and your dad jumped the broken fuse, and your iphone works on a wall charger but shuts down on your PC, I would change the battery. I believe that this is a part of your problem. The output from the wall charger has a higher amperage than your PC. Of course connect your iPhone to a USB port that comes directly of the motherboard. On a PC it most likely a port in the back. Do not use a hub. Give it a try. I know you mentioned that your dad measured the voltage but the amperage is what is mostly missing to sustain your battery. Good Luck.
完成的
good advice from oldturkey/wiseowl
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Amy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,705
