跳转到主内容
加入维修社区 - 创建账户
Motorola Moto Z2 Play 于 2017 年 6 月发布。它配备 5.5 英寸屏幕和 3000 mAh 不可拆卸锂离子电池。其后置摄像头为 12MP,前置摄像头为 5MP。型号为 XT1710。
Screen turning Black when using
Whenever I open an app randomly the screen turns black but the I can still hear the music I am listening to
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Try this first
To reboot the Motorola Moto Z2 Play, press and hold the power button on the side of the Motorola Moto Z2 Play until the screen turns off.
Update: Alright, I'll list parts and guide. But honestly it sounds like software, and parts aren't cheap. You should try saving your data and doing a restore
https://m.youtube.com/watch?v=L
https://www.googleadservices.com/pagead/...
https://m.youtube.com/watch?v=CjvbnfAIER...
这个答案有帮助吗?
得分 2
3条评论:
I have tried this but it didn't work
由完成的 分享
Buy an iPhone.
由完成的 分享
iPhone is garbage 😂😂😂 if you dk this I'm scared for you
由完成的 分享
添加一条评论
First thing you must understand if is an hardware or software problem.
In my case it was an hardware problem.
During display substitution proximity sensor was not clean or some glue went above it, or the display was not enough attached to the body (too much pressure breaks the display, too low let it lifted….not easy to mount it properly)
I cleaned all the area in the upper part of the phone, i removed the old glue.
With the display still mobile i tried an app called “Proximity Sensor Reset/Repair” by Mobile Direction.
I did the test (green light means sensor not activated - red light means sensor activated), i did a new calibration, reset phone and it worked.
No more blank screen during calls.
If i put the phone near or far it blanks or lights up…..problem solved (Moto Z2 Play)
这个答案有帮助吗?
得分 1
添加一条评论
Hay i have a solution for you
https://biomynt.site/moto-z2-play-screen...
Just go and solve your issue
这个答案有帮助吗?
得分 1
添加一条评论
I was also facing the problem i solved it by pressing power up + volume down button this is where i found the solution https://okadtech.com/moto-z2-black-scree...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rehan Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 8,753
