跳转到主内容
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
68 个问题 查看全部
Nexus 6 Damaged USB port, not able to transfer data
Hello,
I have a problem with USB in my Nexus 6. I'm not able to connect phone to the computer via usb cable to allow data transfer but I'm able to charge my phone using it (also when plugged to the computer). USB port was damaged when I have connected my phone to the front panel USB. Front panel was connected to wrong socket in the motherboard ( front panel was connected to the IEEE-1394 header instead to usb header)
Do you have some idea what element on nexus 6 motherboard could be damaged?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Krzysztof Porczyk there is no specific component that we can say has failed. Best you can do is to disassemble your Nexus using these guides Nexus 6 Then post some high resolution pictures of your motherboard etc. with your question so we can see what you see. Use this guide for that Let's see if we can find out what may have failed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Krzysztof Porczyk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 434
