跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
power button not working
(My English conversation is really really really bad. I'm sorry.)
A few weeks ago, I opened my macbook; problem is CPU temperature and cooling solution. My conclusion is simple maybe - paste new thermal paste and get rid of all dusts inside macbook.
So, I saw macbook disassembly in this site and follow the steps and reassemble it. Assemble might be perfect, but power button not working :-(
But, connect power cable, macbook boot automatically, saw apple logo. Shut it down and connect power cable again, but none of the work.
Power charging works good, battery check button also works good, but power button.
What is worng?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Grace, don't be afraid to post your original language as well letting us to the conversion some of us are bilingual ;-}
完成的
While you in there did you see any oily looking reside on the logic board around the heat sink?
完成的
添加一条评论
2个答案
已选择的解决方案
I'm suspecting you didn't get the ribbon cable from the keyboard seated fully review Step11 in this guide: MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement, I use some electricians tape to create a pull to help in holding the cable in place as I latch the latch. Also make sure you haven't torn the cable as that can also effect things.
Disconnect the battery and re-attach the MagSafe charger the system should spontaneously start, if not you have to go back into the system and review what you did as something was forgotten or damaged.
这个答案有帮助吗?
得分 3
2条评论:
It works! Appreciate it.
完成的
Mine started working after I disconnected the power button from the main board!
完成的
添加一条评论
Try taking it apart and try the power button while it's apart. If the power button is working when it's taken apart then it's an assembly connection issue. So check the cables connectors and flex ribbons to make sure all connections are connected and not tweak on the side. I'm trying to picture it in my head how you took it apart, however since you did to clean the DUST from the insides. There shouldn't be an issue with the power button. Thanks hope this helps
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Grace 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 8,620
