跳转到主内容
加入维修社区 - 创建账户
戴尔台式机的维修指南。
computer want turn on
I added memory to a dell 2400 desktop and right after i did this i went to turn it on and it did nothing. No green power light indicator or nothing. Please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Remove your memory and see (actually hear) if you get a post error code usually a couple of beeps depending no your BIOS. If you get the beeping, your CPU is okay I would reset my CMOS and reseat just one memory module and see if it boots up. You may have incompatible memory, or a module that is faulty as well as a module that is not inserted properly. What mother board do you have? I believe that for that particular PC each memory slot can hold DDR PC2700, DDR PC3200 with a maximum of 1GB per slot, and remember that your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system Good luck and let us know how it is going
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wilkes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 432
