跳转到主内容
加入维修社区 - 创建账户
东芝 (Toshiba) Satellite C75D 笔记本电脑。属于东芝 2013 年发布的“经济型”C 系列笔记本电脑。
How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It looks like it's a cable as in Step 10 here: IBM ThinkPad X41 LCD 屏幕更换
or in Step 12 here: ASUS K75VM 液晶屏排线更换
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Toshiba Satellite A215 拆解
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
Toshiba Satellite A215图片
指南
难度:
中等
IBM ThinkPad X41 LCD 屏幕图片
指南
难度:
中等
30 minutes - 1 hour
Asus K75VM 更换损坏的液晶屏排线图片
指南
ASUS K75VM 液晶屏排线更换
难度:
中等
25 minutes - 1 hour
这个答案有帮助吗?
得分 2
2条评论:
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
完成的
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
完成的
添加一条评论
添加你的答案
Marie OKeefe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,952
