Error i20 after several drain attempts
Electrolux Dishwasher ESF66860WR
When I start any washing program the drain pump starts running several times for about a minute, then it shows error i20.
Drain pump itself works perfectly, if I add some water in the machine it goes away. I've opened the drain pump just to check, it is clean and looks OK.
I guess there should be water level sensor which may become dirty, but I can't find it.
Does anyone have an idea what could be wrong?
Thanks in adance for any help!
5条评论
Hi D. Bagaiev, I have same problem with you. Can you deactivate the sensor that you say above. İf yes pls explain me how is it? Thans.
由 kadir aktaş 完成的
@kadir52 same make and model dishwasher? Same error code?
由 oldturkey03 完成的
Yes the same error and code.
由 kadir aktaş 完成的
I have i20 code on my electrolux dishwasher I’ve change pressure sensor it came on but won’t drain water
由 Noble Thomas 完成的
I purchase this dishwasher and every 3-6 months I have the error code I-205-apparently Westington appliances aren’t what they used to be, I will not purchase another one again. It’s only been three years and it’s time to purchase another dishwasher, I can’t afford not to
由 ggren2007 完成的
