跳转到主内容
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
62 个问题 查看全部
Why is the solder different on my Xbox one elite controller?
I am trying to replace the thumb-stick module on my Xbox one elite controller, because it started to drift. But, the solder on the thumb-sticks is not the same kind of solder as the wires that connect the rumblers to the controller. The solder is much different and does not come off with my soldering iron. I need major help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
You need more heat . The part is in the ground plan of the circuit board. the ground plain is soaking up your heat and it will take longer to remove the solder. Try adding new solder to the old too .
完成的
添加一条评论
1个答案
@roseretro not quite sure where you see a difference. Attach a couple of images what you are looking at with your question. For that use this guide. It may help to clarify.
To unsolder it you will have to have a hot soldering iron, some solder wick, flux and solder. Heat your soldering iron, clean the tip of course. Apply flux to the solder to be removed and the soldering wick. Then apply some solder to your hot soldering iron tip and place the wick over the solder and heat it up with your soldering iron.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rodrigo Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 27
总计 2,091
