跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
How can I test the Power Supply 310 W LiteOn (voltage values)?
How can I test the Power Supply or Backlight Board (voltage values)?
Power Supply 310 W (661-5972) (LiteOn)
Backlight Board 661-5980
Model: iMac 27" - Mid 2011 - 3.1 Ghz
AMD Radeon HD 6970 1Gb.
Black screen, no power beep, fans spin, cd drive sound, no led keyboards.
Board Leds Behavior:
led 1: on
led2: on
led 3:off
led 4:off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Although it is very probably that the videocard is the person in charge of the blackout, really I would like to discard any flaw in the Power Supply and the Backlight Board.
For it it would be useful to measure the voltages
完成的
添加一条评论
1个答案
已选择的解决方案
This sounds like a GPU issue which is well known on this model. To test, hook up an external monitor.
Apple did do recall for these models but it has now expired:
The problems have been documented over the past couple of years on Apple’s own Support Forums.
Additionally, the iMacs must fall in the following serial number configurations:
The last four characters of the serial number must contain one of the following groups (for example, xxxxxxxxDHJQ):
DHJQ, DHJW, DL8Q, DNGH, DNJ9, or DMW8
DPM1, DPM2, DPNV, DNY0, DRVP, DY6F, F610
Here's more info on it: https://9to5mac.com/2013/08/16/apple-ope...
A hot air station reflow of the GPU card has been effective as a fix.
这个答案有帮助吗?
得分 2
4条评论:
(A hot air station reflow of the GPU card has been effective as a fix.)
OK. Would a dryer of powerful hair work?
By how much time would heat be applied to the GPU?
完成的
No a hair dryer won't cut it.
完成的
Here is just to reiterated what @mayer is already guiding you to:
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• First disconnect the power cord from computer, then reconnect it to reset the LED
status, in case computer was correctly shutdown and AC was kept connected since
• Verify AC source
• Verify known-good power cord is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that the MXM video card is seated properly
• Verify if boot chime is present and fans are running when powered ON (reset SMC and
PRAM, reseat or check backup battery if necessary for proper boot up):
If POST boot chime is not heard, go to No Startup symptom flow,
If POST boot chime is heard, go to No Video symptom flow.
LED #1 + LED #2 + LED #3 + LED #4 = Power available, system is powered on, video card
found, and internal LCD found.
'''If fourth LED is not visible after power on:
• Verify internal DisplayPort cable connections between LCD panel and logic board
• Inspect LCD display cables for cable damage
• Verify external video functionality, and according to result check the following items:
If external display works then verify/replace the LED backlight board
If external display works then verify/replace the LCD panel
If external display does not work verify/replace the logic board'''
完成的
The computer goes a damaged month, but 2 weeks ago,
I started the computer and there was no changes (not screen, fans activity)
and I forgot the matter for a few hours,
when I returned the fans they were to full and the computer was alive again,
it started normally, worked 2 days and later it went out again.
I have tried to repeat this event without success.
完成的
添加一条评论
添加你的答案
ned flanders 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 495
