跳转到主内容
加入维修社区 - 创建账户
Reset loop - Apple Logo/Red Cross
Hi
I have a 3rd gen Nano 4gb that is caught in a reset loop. The Apple logo appears for a few seconds then it goes to a red circle with cross in before looping over and over.
If on AC it loops the Apple logo to 'please connect to iTunes'
Things I have tried:
~ Diagnostic mode - passes all ok
~ Reset
~ Disk mode - does enter disk mode and iTunes will prompt to restore but resets before completion.
~ Restore mode - after a reset it doesn't stay on long enough to enter
~ Hard reset - doesn't appear to work
Any other ideas what i can try?
PS
No water damage, never opened.
Cheers
Neil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Neil, I would start of by replacing the battery if you have not already done so. The errors that you are describing seems to change with the AC power connection, usually that does not happen unless you have (also) a battery that is either bad or going bad. Just a start and I hope that it will help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 3,200
