跳转到主内容
加入维修社区 - 创建账户
CB Radio (all types) first introduced in 1958.
Applied too much voltage
My power supply malfunctioned and started delivering 24v instead of 12v. Unfortunately i didnt notice untill i had keyed a couple of radios. The receive still works but the transmit does not or is very weak. Which component (s) are likely to fail when too much voltage is applied? What section would i start searching?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@oldturkey03 thanks for the reply. Its a uniden president radio and i looked at the boards and everything looks fine. The power output is swinging to 2w barely transmitting. Was working perfect until i plugged it in to a power supply i got as a gift.
完成的
Can you post some images while I check to see if I have more info on that model? There are about 10 different Uniden President radios. Any chance you can narrow it down?
完成的
uniden president mckinley
完成的
添加一条评论
1个答案
@jhawks there are no standard items of things that fail when receiving to much power. It could be a couple of the diodes on the inside of your radio. You will need to let us know the make and model of your radio. It might also help if you take the cover of the radio and post some images of your circuit boards. Use this guide for that so we can see what you see.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hawk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 873
