跳转到主内容
加入维修社区 - 创建账户
于 1990 年发布,是 Apple Extended Keyboard 的后续产品。生产型号为 M0312 和 M3501,采用了传奇的 ALPS 触感开关或 Mitsumi 标准机械线性开关。
Removing the metal frame
Hello there,
The ^/ ° key went dead, so I soldered a new ALPS tactile switch onto the back - and all of a sudden two more keys refused to function: a & </>
While reassembling the AEK I noticed a copper strip, about 52 mm x 2mm with a drilled hole at one end of it, which hadn't been there before and presumably fell from somewhere between the metal plate and the mother board.
Is there a way to separate the metal plate from the AEK's mother board?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Is this what you are trying to do?
这个答案有帮助吗?
得分 0
添加一条评论
Probably a late response but yes, the metal plate can be removed. The only thing holding the steel plate to the motherboard are the switches.
Just have to desolder every single switch .
Once desoldered, just lift the plate, or take out each switch one at a time. Use Rosin Flux and a clean soldering iron tip to avoid damaging the pcb, since it is very old at this point and it is very easy to raise these old solder pads (once you do, they’re gone forever).
Course, that’s a huge hassle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jirudo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 655
