The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that. Most likely soldering a new connector to it should resolve the problem.
指南
难度:
非常容易
2 - 5 minutes
指南
难度:
困难
6 minutes
这个答案有帮助吗?
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,069
