跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
worst gps and wifi signal
Hi everyone!
I have soo much problems with the wifi connections and signal, and the gps has no works properly. I have two aircloud blocked iphone 6, for replacments and spare parts. What can I do? I saw it in google that maybe I need to replace the logic board or wifi antenna...but I'm lost. If I change the logic board, I need to change the touch id sensor (fabric paired), but I don't know if it works because this iphones are blocked...
Thank you soo much in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@uriveres let's start off with making sure that you cannot use the icloud locked boards. Those are only good for parts, not for use.
Update (09/24/2017)
@uriveres it should unless it is your antenna that is at fault. Consider changing the WiFi antnna first. Use this guide iPhone 6 Wi-Fi 天线更换 for that
这个答案有帮助吗?
得分 2
2条评论:
@oldturkey03 thank you. So...if I buy a new logic board and replace it the gps position and wifi will work properly?
完成的
This is a motherboard problem.
I have the exact same problem with my iPhone 6. It isn't able to receive the cellular signal. The Apple store said that it's most likely a cellular antenna and or motherboard. Neither one of them were recommended to be repaired. They offered to replace it with the exact same phone for $300 and WOULDN'T guarantee that the fix would last more than 30 days. My guess is that you should trade it in for a credit.
完成的
添加一条评论
ill go off the wifi antenna path and say look at the logic board antenna cable for your wifi/gps antenna. mine is crook after buying a used iphone 6 and waiting on the part to fix it. i suspect the previous owner got the screen replaced by some dodgy person that may have swapped the part out???
here is the repair i am talking about: iPhone 6 Antenna Flex Cable Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
uri veres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,801
