跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Why won't the headphone jack or lock button work?
Today, the headphones jack in my iPod started only playing through one headphone. I tried the headphones with my computer, and they worked fine. I switched the headphone jack and lock switch assembly with that of another iPod, and got the same problem, but now the switch didn't lock it either. I figured that it must be the logic board, so I switched that, but it still didn't work. Does anyone know what might be going on here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@treeofeden make sure that you are using the right headphone jack/hold switch assembly. It has to be for a 5th gen iPod. They are not interchangeable. Since you already swapped the logicboard it is unlikely that both have the identical error. I suggest that you get a known-working assembly from places like this iPod Video 30 GB Headphone Jack & Hold Switch and make sure that you identified your iPod properly. the Video is not a Classic etc.
Includes headphone jack & hold switch图片
产品
$29.99
这个答案有帮助吗?
得分 2
4条评论:
Both assemblies came out of working 5th gens, I'm certain that they are correct.
完成的
that is a very odd situation. You checked to ensure that they are working?
完成的
@oldturkey03 they both were functioning perfectly until I tried to use them this one time.
完成的
This is truly strange but may point toward a need for another working logic board. There is not much known about the schematics of these boards. Other, of course, than the issue with the audio IC loosing contact. Squeeze the audio IC location and see if that makes a difference while you are playing music.
完成的
添加一条评论
添加你的答案
Harris Edenbaum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 118
