跳转到主内容
Collection of repair and disassembly guides for DJ Controllers.
Numark Mixdeck Express keep shutting off and on
My Newmark Mixdeck Express keeps shutting on and off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Why does my keep cutting please
完成的
i use gotv adaptor to power my numark mixdeck quad and it keep oning and off what can i do
完成的
添加一条评论
2个答案
最有帮助的答案
Mark Zellous appears to be a protection circuitry that prevents your controller from powering up. You will have to open it up and take a look at the power supply. Check the MOSFETS and capacitors for obvious damage. There is not a whole lot of information about your device out there so we will have to go by trial and error to help you with that.
Depending on the age of the controller and where you purchased it from, you do need to check for any warranty etc.
这个答案有帮助吗?
得分 1
2条评论:
完成的
@sunshinesai8393 tell us more about what this adapter is. What voltages does it deliver? What have you checked?
完成的
添加一条评论
My numark mixdeck express cuts off why I'm djing
Update (04/03/2020)
I be playing my numark mixdeck express an its cuts off cut back on then it stop want do nothing
这个答案有帮助吗?
得分 0
2条评论:
Have you checked to make sure your USB port isn't loose and possibly causing the short. I repair these type of units and I see the USB ports go bad on these or sometimes there might be a bad cap or something short circuiting in the power line.
CoCo The Geek
完成的
完成的
添加一条评论
添加你的答案
Mark Zellous 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 1,338
