跳转到主内容
The RCA Voyager II is a 7-inch tablet produced by RCA.
67 个问题 查看全部
My screen is stuck on
when i turn on my screen it it stays on the screen that said voyager .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 18
6条评论
how do you fix it
完成的
I did all of that and all it does is turn back off it's still not working don't know what to do at this point HELP PLEASE…..
完成的
Same here. Piece of junk
完成的
when the tablet gets stuck on the rca screen how do I fix that
完成的
how to fix a rca screen
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
Courtney Lord sounds like your tablet has issues with the Android operating system. You may have to try a factory reset by booting into recovery mode. Powered the tablet off making sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should see an android image. Press and hold the power button and tap the volume up button once more and you should be in the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet it should now be set to factory original settings.
这个答案有帮助吗?
得分 6
4条评论:
I did all the reboot and table hard reset but the keys will not work on my tablet
完成的
Same thing happening to me
完成的
I was dumb enough to buy a second rca tablet for my grandson only to have both of them stuck in limbo...the reset does not work on either one...everything was tried just as told but same screen...they will not go to any other screen...
完成的
It worked thanks!
完成的
添加一条评论
Press the power button, then volume up, then volume down. Then wait.
这个答案有帮助吗?
得分 3
3条评论:
What if I don't have keyboard?
完成的
You don’t need a keyboard. Use the PHYSICAL buttons on the tablet.
完成的
It worked. Had to do it a couple times but it worked. Thanks!
完成的
添加一条评论
What you are gonna want to do is,
  1. Press the power button.
  2. now press the volume up button
  3. lastly, press the volume down button.
  4. so basically, press the buttons going from up, to down.
这个答案有帮助吗?
得分 0
1条评论:
How long does it usually take to get passed the voyager screen after I do all of that?
完成的
添加一条评论
添加你的答案
Courtney Lord 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 17,121
