跳转到主内容
The GoPro Hero3+ Silver Edition (model no. CHDHN-302) was released in October 2013. This digital camcorder is capable of recording 1080p HD resolution video and taking 8MP pictures.
17 个问题 查看全部
Can I use replacement battery 1290amp 4,7Volt
My orginal battery for my Hero 3 Silver is nearly dead, so I am planning to buy a replacement ones from net. They do offer with higher amper and voltage, if I use those, would they damage my gopro? I guess same will occur for my Hero 5 soon too. I do really appreciate your answers, thank you very much in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@serkanistan higher mAh will be ok, higher voltage will not be. Stick with the batteries that are meant for your device so as to not cause any damage or fall into a trap of better batteries. Most of those are no better than an original. If you purchase your battery from here you will at least know that it is the right one and that you are going to get a good quality battery.
Replace a AHDBT-201 or AHDBT-301 model battery compatible with a GoPro Hero3 or Hero3+. 1600 mAh. 5.9 Watt Hours (Wh). 3.7 Volts (V).图片
产品
GoPro Hero3/3+ Battery
$12.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Serkan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 94
