跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Bottom Screen Flickering Light Blue when analog is moved?
So I just bought a second hand modded 3ds xl console (katsukity mod) This is from another owner not the original company. The issue is that when I'm playing a game or if I apply a little pressure to the left side of the 3ds (the side with the analog stick) the bottom screen will spazz out and basically flicker a bluish filter over bottom screen image, it still displays it's just discolored and I'm afraid this will cause the screen to stop working altogether.
This issue wasn't described in the item description so I feel it might have happened during shipping because the box used was too large and the small box for the 3ds probably bounced around.
It specifically happens if I pinch the top left side of the analog stick and the bottom of the 3ds a little bit. So that explains why it happens when I move up and left as I imagine my hand would put more pressure on the 3ds in this situation.
I looked at the diagrams and such here, it seems that there is a ribbon cable (in the picture on here , on the top right of the 3ds's bottom half) I'm not sure if this is connected to the screen but would applying pressure to this ribbon cable cause a symptom like this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Yes, you should check that ribbon connection, make sure the cable is seated properly and does not move around.
This guide will help you disassemble the console and get to the problem area:
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kevin Jiang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 710
