跳转到主内容
Repair and support for the third generation of the Flip portable speaker by JBL.
Little part fell off the JBL flip 3 motherboard labeled 1R5
I dropped my JBL flip 3 speaker the other day and I started to hear a rattle inside so I decided to take it apart and see what it was and it was a small box at the top Corner of the motherboard labeled 1R5 and i don't know how to put it back on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Exact same problem has happened to me, does anyone have a solution
完成的
the same excact thing happened to me
完成的
添加一条评论
3个答案
@mtz13 without actually seeing what is going on, it is difficult to answer. Consider posting some picture of your board with your question. Use this guide 在已经存在的问题里加入图片 for that. The 1R5 sounds like a fixed 1.5uH inductor. Again without seeing it, this is only an assumption. Those are usually soldered to the board and there is not other way reattach it.
这个答案有帮助吗?
得分 0
添加一条评论
Something similar happened to me. The 1R5 piece didn't break down fully and now one contact is lose. I think the only way is to solder it down. https://imgur.com/a/2y4Xy
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem and solved it by cutting a wine cork in size to press the 1R5 piece against the contact. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 7
总计 1,551
