跳转到主内容
Repair and disassembly guides for Mixers.
How to Remove the Switch to Repair Internal damage
The switch on my Kenwood Major A707A is damaged and now it just turns without switching on the machine. I would like to open the machine and replace the switch or damaged part inside the casing. If someone could give me detailed instructions on how to do this I'd be very grateful . Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@eamonn1949 here are the instructions from 1971 :-) Not easy to read and the number in the brackets refer to the parts in the parts list. This will help to identify what and how to take it apart. Scanned it a bit to heavy so I needed to create two parts. Kenwood-A707a-Major-disassembly-Part-1.pdfKenwood-A707a-Major-disassembly-Part-2.pdf
Here is the schematic and the wiring diagram
这个答案有帮助吗?
得分 0
添加一条评论
The trick is to dismantle the machine from the bottom up. Put it upside down on your workbench. Take off the cable box. Then remove the motor cover. You need a 8 mm hex wrench, a Torx and a Pozidrive #2 screwdriver. When the motor cover is off, you can push out the hinge axle. Voila! I found out the hard way. But here is a neat movie on YouTube. https://youtu.be/Hw-L6Dk9eL4
I, too, had problems with the switch. Somebody had cranked it up too far, and now the speed would start at maximum and the you had to crank the speed down not up! Another symptom is that you can turn the speed knob 360°, not just 180°. Unfortunately, the spare speed regulator is sold out.
I found the solution only at the second attempt. It depends how the spring actuating the speed knob is put in. The left limb of the spring holds the swivel actuating the maximum speed switch. No problem here! The right limb of the spring has to put in in a way that it obstructs the path of the white pin sticking up from the dial. If put in correctly, you can turn the knob 180° only. If the right limb of the spring it above the gray plastic edge, it will not engage the pins on the knob, and the knob will turn 360°. Just put in the left limb of the spring correctly.
That's it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eamonn Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 821
