跳转到主内容
加入维修社区 - 创建账户
Ultimate Ears 生产的一款便携式蓝牙音箱。
It will not charge?
Whenever I plug the power adapter into it and I charged it for over two nights and I go to turn it on it says critical battery please charge, then shuts off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
Thanks. I will give it a try.
由完成的
Do like i did, get mad, throw it at the couch, curse at it ,grab it then choke it, tell it sorry, plug it in and there it goes still not charging ,please help ,this thing isnt helping me with my anger management classes
由完成的
May just need a new battery ;-}
由完成的
添加一条评论
6个答案
最有帮助的答案
Is the charging LED lit when you plug in the charger? It should be blinking. If not the USB port may need replacing.
这个答案有帮助吗?
得分 3
8条评论:
It rapidly blinks, unfortently
由完成的
That sounds like a dead battery.
由完成的
When you say dead battery, does that mean it will no longer accept a charge?
Mine was sitting in the closet for months and I charged it overnight, light was blinking, it says it's charging when I try to turn it on but he no charge the next morning.
由完成的
Courtney, Yes if the White LED just above the USB port is blinking. If the LED is not lighting up then the charger, cable or the USB port its self have failed so the unit is unable to be charged. If the LED is blinking and never gets to a steady state then the battery has failed (this is when the onboard voice will tell you: "critical battery please charge" and the On/Off LED will be Red.
由完成的
Mine just says"recharge battery" but won't take a charge. I play it often. I leave the charger in when I'm playing but it still looses it"s power.
由完成的
显示更多的3条评论
添加一条评论
Purchased one 2 days ago that was on 28/12 /2017...needed recharging the next day.. charged it overnight, next morning saying battery critical again! So problem solve with YES you guessed it utube.. watched several & after doing everything but put it in the fridge like one guy suggested
这个答案有帮助吗?
得分 1
添加一条评论
The charging led on mine only flashes when the battery is removed.
Speaker works normally with no battery fitted, but does not switch on with battery in.
Shows 40% charge with or without battery.
这个答案有帮助吗?
得分 0
1条评论:
does it mean you have to replace the battery?
由完成的
添加一条评论
Unplug the charger and put it back in then wait 40 min then test it
这个答案有帮助吗?
得分 0
添加一条评论
The issue I have with mine is I believe a USB port issue. I have to fight it in a specific angle/way to start charging. It's not plug & charge for me. When I do get the charge indicator to appear, 24 hours later the speaker turns on but then critical battery please charge then off.
I think the charge port is the issue for me.
It's too weak to let me play music from it to see speaker quality.
这个答案有帮助吗?
得分 0
1条评论:
Check this guide out Logitech UE MegaBoom 辅助接口和 micro USB 接口组件更换 You will likely need to find a replacement port from a junker or see if you can still find a spare.
由完成的
添加一条评论
My UE MEGABOOM only was playing while charging. When I displuged, it stopped playing (but da light of the on/off button was still on and my phone was still reconizing it on the bluetooh).
I did the following steps said by Andrew Pifferini  on the link below:
Why won't my speaker turn on?
Now is playing without the charging cables.
Hope this helps;
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Morazes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 41,810
