跳转到主内容
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
37 个问题 查看全部
Not working. No display. Better also changed. what should I do?
My Casio fx991 es plus calc not working what should I do? No display battery also changed. Advise me please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
14条评论
My Calculator display is gone. How can I repair it
完成的
Not working properly only working solar power not working on
完成的
It is not working and displaying.
完成的
Not working and not displaying
完成的
CASIO fx-991ES not working even though replacement of Battery. But its working with solar. pls suggest any things for resolve.
完成的
显示更多的9条评论
添加一条评论
8个答案
最有帮助的答案
same problem occured my casio fx-991es plus. i changed battery same problem occured not turn on my calculator but working while solar. so i opened my calculator i check the wire connection solar wires are connected properly and battery black wire it mean negative line cut down. i fixed that issue now my calculator working finely. thanking you.
这个答案有帮助吗?
得分 4
5条评论:
Can you please tell me How did you you fix the issue
完成的
Same problem can u say me clear procedure
完成的
can you please tell me in what place where the black wire should be connected? thanks in advance
完成的
I had the same issue, replaced battery but still didn't work but it works on the solar panels if flashed with a light source. I opened my unit and what happened to my calcu was the black wire were slightly corroded and a with a touch it suddenly snapped at the soldered point. I soldered in back in place and it came back to life.
完成的
You re lie I am calcalater man I rip all tha calcs thats what us pros call the calcualtors dont worry I can help at all points just come to address here namaste fremnd Dundrum Rd, Friarland, Dublin 14, D14 W0V6
完成的
添加一条评论
@shah313 double check to see if there is a reset hole on the back of your calculator. Use a small object to depress the rest button in there. Let us know what you find.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your answer but my calculator still at same position.
完成的
I pressed the button but still, nothing happened.
完成的
Thanks for ur answer my calculator start working
完成的
添加一条评论
On the back there will be a “P“ button in the middle. Press it and see if there is a difference.
这个答案有帮助吗?
得分 0
添加一条评论
I saw that the calculator was solar, so then I took my device and turned up the brightness and faced it to the front of the calculator. It started turning on
这个答案有帮助吗?
得分 0
1条评论:
I most likely shouldn’t have been doing my assignment in the dark in the first place ^3^
完成的
添加一条评论
As it’s screen is not showing anything; Consult with any technical expert as there may be some internal faults which can’t be solved verbally.
这个答案有帮助吗?
得分 0
添加一条评论
Same thing also happened with my calc. So i was searching for the reset button but couldn’t find any at the back. So what i did was i tapped the calc around the solar plate area with my fingers three four times and then pressed the power button. And it turned on.
这个答案有帮助吗?
得分 0
1条评论:
I dont know how , but your method worked :lol
完成的
添加一条评论
I had this problem too I opened my calculator still couldn't figure out what was the problem so what I did was my cal works on solar power as well so I turned my cell phone flashlight on and I held my calc display in front of the light and it worked it's not supposed to work when I light is
这个答案有帮助吗?
得分 0
添加一条评论
Lose the calculator
Locate the power button area
Find a screwdriver and use it to scrap/scratch the power button area on the motherboard gently.
This works for me💥
Reach on Whatsapp at +2347068995770 for more explanation.
Taotech Solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shahzad 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 76
过去 30 天: 300
总计 45,099
