跳转到主内容
加入维修社区 - 创建账户
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
Why don't I have spark
Have changed plugs, plug wires, crankshaft sensor, camshaft sensor, coil pack, ignition module, and checked the neutral safety switch. Still have no fire. Why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@hostile contact me by email if you need the SM for your Neon.
完成的
添加一条评论
1个答案
已选择的解决方案
@hostile this will be difficult since you've already changed the most common faults. Check the voltage to the coil pack and you should get 12V on the center wire and 12.27V - 12.63V on wires 1 & 3 when cranking. Also check the voltage at the cam and crank sensors which should show 0.03-6.34V. Right now it appears as if you are having issues with the PCM.
这个答案有帮助吗?
得分 0
1条评论:
Yeah, that's my very next buy. Was pricing it 2day.
完成的
添加一条评论
添加你的答案
Joseph Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 311
