跳转到主内容
Refrigerator and freezer not cooling.
The lights in the fridge and freezer flash non-stop( not sure if these two problems could be related?); this isn't a big deal, because I can just turn the lights off. The second thing is that it just stops cooling in both fridge and freezer out of nowhere. I think when we replug it in it works for a little while, and then stops working again. Thanks! http://www.refrigerator-reviews-ratings....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This has happened to many others. It appears to be a factory defect. Try unplugging it and plugging it back in. Here is my previous answer on this including the defect link:
Whirlpool Refrigerator Interior Lights Flickering
这个答案有帮助吗?
得分 2
添加一条评论
Power Socket or plug Issue , Just make it sure that it has no loose connection,
Please check also the Proper Voltage from your Main AC Source . 220 VAC or 120VAC
Extreme carefully handling Power,
make sure safety first, avoid electrical Shock.
No Wet Floor and Foot upon plugging and unplugging AC Mains.
这个答案有帮助吗?
得分 1
2条评论:
Thank you, I'll check that.
完成的
Your Welcome just keep us posted for the progress ^_^
完成的
添加一条评论
添加你的答案
Sherry Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,157
