Is my sd card slot broken?
Says can't use this memory card. Menu skips right over format card option.
Says there is a card in when there isn't.
@jsd9086 it is possible that the card reader thinks a card is inserted due to a bend or stuck switch. Your reader will have one tab that gets moved away when you insert a new card and thus recognizes that. If that tab is no longer working properly, your camera will be told that a card is inserted. Of course, you also should try a different memory card. Use these guides to work on your camera
这个答案有帮助吗?
Thank you oldturkey03
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 122
