跳转到主内容
Repair and disassembly guides for guitar amplifiers.
71 个问题 查看全部
Can I run my marshall amp head thru my line 6 combo amp to test?
hi. I have a used Marshall mg100 amp head only - I do NOT Have a speaker stack to run it through or even test it out.......
I have a Line 6 1-12" combo amp....
is it possible for me to plug into the line 6 amp for speaker only - and not power up the line 6 amp? Just to test the Marhall head?
I've never tried it before......and I don't wanna blow either amp.......
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I basically just was wondering if I could just plug in and the speaker would work thru the back speaker jack on the line 6 amp - WITHOUT powering up the line 6...... (basically just use the speaker in the line 6 amp as a "speaker box" ......?
完成的
I figured that is what you were trying to do. You hook one output of an amp to the input of another that is not expecting (or designed to do so) it, you are possibly going to blow your preamp stage.
完成的
添加一条评论
1个答案
已选择的解决方案
Gregory Justice sounds unhealthy to run an amp through another amp. Something is going to fry on your Line 6 amp.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gregory Justice 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 157
