跳转到主内容
The OnePlus X smartphone was released in November 2015 by OnePlus. It is identifiable by model number E1005
Dropped in water. Touchscreen works. Display will not turn on.
So my phone (OnePlus X) has went through some pretty heavy water damage. After leaving it in rice for a few days, it was working perfectly fine. Today, literally a week after, the phone display isn't working.
When I power on the device, a few green lines flash for a second on the displaying, showing me that it is on. I can use the phone but there is nothing on the screen, it is completely black. When I press the power button again, turning it off, a small, vertical green line can be seen running along the middle.
What exactly do I have to get repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@youarereading "leaving it in rice for a few days, it was working perfectly fine. " Nope! It is not fine. While you let it sit in rice, corrosion set in, residue seeped under components and was left behind while water around it evaporated. This creates short circuits and components will fail. Rice does not work! It does not do anything. It does not repair your device nor does it prevent corrosion.
You need to try to resurrect your phone if you are wanting to fix it. For that, you will have to totally disassemble it. Use these guides to at least get into it. This video will also help you. Once open, clean it with a soft brush and 90%+ isopropyl alcohol. Use this guide for the cleaning. Even so it was written for an Apple iPhone, all the steps are still pertinent to your phone as well. Remove all EMI shields of your motherboard to clean it properly.
Once it is cleaned reassemble it and replace the battery. This is a must since it will fail. Then check your One Plus X for proper function. If you do not take care of the water damage you cannot properly troubleshoot your damage.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Amrit Matharu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 1,978
