跳转到主内容
加入维修社区 - 创建账户
Asus Republic of Gamers G20 是一款小尺寸游戏台式电脑,具备发烧级组件和良好的性能。于 2014 年发布。
Screen frozen on ASUS startup screen.
PC won't proberly boot, gives me an option to enter BIOS, if I leave it, it will just stay on the ASUS logo and a black screen. Previously I had a problem with the PC after a failed update. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Umm... Hi! I've been having the same issue and i'm wondering how you solved it. It would be great if you could get back to me, Thanks.
完成的
I have the same problem got it from my step brother and it worked fine, but then sat for about 4-5 months and now does this.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @robert1201,
what OS are you using ?
before any failed updates, do you encounter any issues, like bsod or poor performance of the pc?
I suspect either the operating system has crashed or hdd issues
If possible do a check on the HDD, hopefully inside bios has an option to test out.
check inside bios if your hdd is able to detect.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Mullins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,220
