跳转到主内容
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21 个问题 查看全部
Source for procuring quality replacement speaker for QC25
I have the same problem as described here: How toReplace broken speaker for QC25.
In short, the speaker on my right died.
The question is where to buy the replacement part. It seems that this part is available on eBay for a range of prices, which warns me for cheap replacement parts.
I am looking for a source for a quality replacement part, in order not force me to replace (=downgrade) the other, currently working side at the same time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@asdmin the only way to get the guaranteed right working speaker is through Bose itself. Contact them and see how much the repair would be. Anything else you'll take a chance but you may just get a good replacement. You can also purchase a complete set that is broke, other than the speaker, and then harvest the speaker from that.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, the suggestion for a broken unit was very helpful!
完成的
Before I blew the headphone up, I called Bose. They will replace mine, as it was affected by a manufacturing defect. Nevertheless your answer is correct and valuable. Now given, that this headphone is serviceable, I'll also look for a broken one for parts. Thanks!
完成的
添加一条评论
添加你的答案
Daniel Vasarhelyi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,600
