跳转到主内容
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
74 个问题 查看全部
Detection of a component on motherboard
Hello.
Can anyone help me with detection of marked component from J5 Duos motherboard?
Looks like somethink wrong has happend..
https://ibb.co/edYuWv
Thanks.
Update (09/11/2017)
Oh, thanks :-).
Phone was probably water damaged. I can see probably salt at two places on top of the borad. One image is from components around WiFi/BT and other image is different side of board - bellow front flash diode.
https://ibb.co/fL3ota
https://ibb.co/nAm8ta
So, phone is KO. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
I think you need to provide some background information. Is the phone water damaged? Does it turn on? Any serious drops?
完成的
is that not a soldered shield over the top
完成的
It is soldered. But what is under?
And can malfunction of this component be reason for no-functional phone?
完成的
I need j5 (2016) Board
完成的
添加一条评论
1个答案
已选择的解决方案
@fbituco you'll find your BT/WiFi under that EMI shield. Could be a reason for non-functional if your BT or WiFi is not working. You'll have to give us a bit more information about what is not working on your phone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fbi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,530
