跳转到主内容
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
25 个问题 查看全部
My tablet it stuck on the rca welcome screen.
My tablet is stuck on Rca booting screen and will not proceed. I have done numerous resets and restarts and nothing is working. I need help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
7条评论
Why does my voyeger tablet
stay stuck on the welcome screen
完成的
I have resurrected one of these tablets from the trash. It charged... Factory reset... And button g several times. Each time it it starts and stops at the welcome screen for choosing the language... The touch screen is not able to select English. Do I need to replace the cracked screen first???
Help... Bert
完成的
Help... Bert
P.s. where can I get a pdf of the repair manual?
完成的
I have the same problem
完成的
My RC tablet is stuck on logo also I can’t get it off or do anything with it
完成的
显示更多的2条评论
添加一条评论
4个答案
最有帮助的答案
@kelbmass15 you are not telling us exactly what you tried. So let's start with that. You said you tried multiple resets and restart but I would try the "Hard Reset". Doing this will erase all your data on the tablet,
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Should this fail as well than you most like have problems with your firmware and will have to try to update/repair that.
这个答案有帮助吗?
得分 5
4条评论:
Would like to get some real help
完成的
Absolutely!! I've tried all that crap! I'm calling the BETTER BUSINESS BUREAU and filing a complaint! This is ridiculous. I want a NEW, FUNCTIONING, tablet. One and a half hours on the hold and hung up. Customer service and support is worse than terrible.
完成的
i tried everything but still nothing
完成的
@Essence Pinckney what make and model tablet. Exactly what did you try? What is going on with your tablet? The more information you give the greater your chance of getting some helpful answers
完成的
添加一条评论
Well i just need someone to tell me how to fix a frozen welcome screen. I beg of your help please and thank you. :)
这个答案有帮助吗?
得分 1
添加一条评论
Hi Kelby
If you fill out his form you will receive a repair authorization number and the address to shop you unit to.
This form is for warranty repairs and non warranty so they will be able to assist you. The link for the form is below. Hope this helps answer your question.
https://rcaav.com/repair/
Use preauthorization code: MKM116
Best regards,
Rhea
这个答案有帮助吗?
得分 0
2条评论:
I have been on HOLD with RCA support for 1 hour and 15 minutes!! I'm hanging up and calling the BETTER BUSINESS BUREAU. This is ridiculous and I'm furious!!!!! Never used this tablet
完成的
this is a new tablet!!
完成的
添加一条评论
If your tablet is stuck on the dog screen what I did was reset the tablet by using a paper clip and putting it in the hole and now try the steps that it says since it is turned off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelby massey 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 53
过去 30 天: 298
总计 13,119
