跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
How to reconnect a controller to the wii
My Wii remote is not syncing to the Wii and I think it might be broken.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My wiimote just blinks slowly ten times. That's all it does. It started a week ago when I was going to play and the remote just slowly blinked ten times. It did not just connect like usual or blink fast as usual. It's very strange and cannot find a thing about it anywhere.
完成的
添加一条评论
4个答案
已选择的解决方案
@jbeckwith try to sync it to your console:"
Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console. When the Player LED blinking stops and stays lit, the syncing is complete."
这个答案有帮助吗?
得分 5
4条评论:
I tried that
完成的
You unplugged your Wii for a while to see if it resets? After that try to sync again or you could try this. Connect by pressing the red button on your Wii remote. It should start flashing for about 30 secs or so. Then, while its flashing, press the red button on your Wii console, open the flap under the reset button to find it. once you have done that continuously press 1 and 2 at THE SAME TIME 10 times then press power button on top left of remote, press the A button and that could make it work.If nothing else contact @tronicsfix and see if he knows of some common errors.
完成的
What happens when i put the red button on the back of the wii controller and it does not flash blue how do i connect it
完成的
完成的
添加一条评论
Its still not working
这个答案有帮助吗?
得分 3
1条评论:
Followed the instructions as told but still after many tries the screen pulls up saying it has lost connection and to hold 1 and 2 on the remote simultaneously to connect.
I even unplugged totally everything for awhile and the same message appeared on the screen.
完成的
添加一条评论
My controller won’t blink at all
这个答案有帮助吗?
得分 2
1条评论:
I HV this same issue with mine
完成的
添加一条评论
I haven’t tried yet i will try with my remote that is not working. Thanks a lot for the infrmation
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jadin Beckwith 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 42
过去 30 天: 133
总计 39,288
