跳转到主内容
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
20 个问题 查看全部
How to fix Start button
My Start button stopped working, which is a letdown, since all my game need the Start button one way or another. I wondered how could I fix it, and of course where to get the part to fix it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi!
Before you order any parts, let's take a look at what the damage might be. Follow this guide and check the rubber membrane of the Start/ Select buttons for damage or cracks. Next check the gold contacts it sits on. These need to be shiny and if there is any gunk on them, you need to clean them up with isopropyl alcohol.
Let me know how this goes.
这个答案有帮助吗?
得分 3
6条评论:
I just ordered the screwdriver kit, so I'll be back with you in 2~4 days.
完成的
Ok, just got the screwdrivers. I opened it up, but the start gold contact didn't have much gunk on it. I did clean it up with some rubbing alcohol (70% Ethanol/30% water), so I'll see if it works when it will be dry. The rubber work as they should.
完成的
For those who may be curious, my GBA missed one screw to attach the circuit board.I wonder if it's Nintendo's doing to lower the cost of making the GBA.
完成的
Oki, it works now. Thank you for the help!
完成的
I'm glad I could help.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Alex Lebeau 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 133
总计 13,750
