跳转到主内容
加入维修社区 - 创建账户
Acer Iconia Tab A700 是一款搭载 Android 4.0 系统、配备 1080p 显示屏、500 万像素摄像头及 HDMI 接口的平板电脑。
Problems in Google Play
I can not download a lot of apps from Google play to my tablet. It keeps saying app is not compatible with this device.. I've also had one app, that when typed in, doesn't even show up. Is there anything I can do about this? Or is my tablet just out of date and not usable anymore? Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I did what you said to do and when I try to check for system updates it tells me there is a network error... and sadly, my android version is only 4.1.1. Does this mean that there is really nothing I can do besides get a newer tablet?
由完成的 分享
If you have a version on an older device, go to Google play, select share, accept share on new device and download. Worked on mine with a banking app.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
It is likely that you need to update your OS. Go to settings go to the bottom where it says "about tablet" and click on it. Then click on check for updates. If it doesn't have an update, then Acer likely dropped support for that tablet and now you won't be able to install many apps. While your in those settings, check your version of Android. Most apps only support 4.4 and up.
Hope this helps!
这个答案有帮助吗?
得分 4
1条评论:
I'm having same problem. My Android Version 8.1 and my Acer is updated. I've turned to Google for answers.
由完成的 分享
添加一条评论
Having the same problem, every time I go to attempt a system update it says there is a network coverage error and that I need better connection, I walked into the same room as the wifi router and it repeated itself, confused to kingdom come at this point, won’t even let me reinstall autotrader
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie Gentry 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 37
总计 7,205
