跳转到主内容
加入维修社区 - 创建账户
松下 LUMIX DMC-LX100是一款发布于2014年的便携式数码相机,她带有12.8MP像素的MFT尺寸传感器,支持4K视频录制,带有WI-FI传输功能。 LUMIX DMC-LX100是松下LX系列第一款采用MFT尺寸传感器的机型。
How do I fix "System Error (Zoom)"
Camera works fine, and zooms between 24mm and 35mm. Try zooming past that and I get a "System Error (Zoom)" message on the screen and have to turn it off and back on.
Presumably this is grit in the lens assembly. Any suggestions for taking it apart and fixing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Yes that's a problem
由完成的
添加一条评论
1个答案
已选择的解决方案
I’ve had this same error, but on startup of the Lumix. The zoom lens was stuck in its position. I disassambled it using the guide here on FixIt, it turned out that there is a fixed lens, which focusses the light onto the sensor. That had come loose (i suspect, because the camera got heated up in a hot room for some time). Fixed it, but unfortunately the loose lens had made scratches on the sensor. So my LX100 is working, but there is a small area in each photo with a image distortion :-(
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alesh Houdek 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 96
总计 10,117
