跳转到主内容
The HTC Desire is the first smartphone of the Desire series developed by HTC.
37 个问题 查看全部
I dont know what happened ...
when i turn on my phone it keeps repeating the welcome window repeatedly.....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Phone is on but no picture no service
完成的
添加一条评论
3个答案
已选择的解决方案
rica, did anything happen to the phone? Any firmware or software updates? Anyhow try this first and see what happens. Hold the Volume - button then press the power button once. You should boot into FASTBOOT. Select BOOTLOADER, and select clear data or something like that. This will do a factory reset for your phone. You may lose your info on there so make sure you have some sort of back up for contacts etc. http://www.htc.com/europe/howto.aspx?id=... and here http://www.knowyourcell.com/htc/htc-desi... is more info Let us know if this helped so we can continue to assist you if not. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem, and after days of searching on internet I realized the problem is the overheating of the CPU which is a hardware problem. Maybe you guys can fix the problem. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
i was restoring the factory setting and during restoring it become dead . i dont know wht happend . can anyone help me to resolve it .????
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rica 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 5,252
