跳转到主内容
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 个问题 查看全部
Wet Samsung j7 is not working properly
what do I do if my phone fell in the water? it is not working properly. it is very difficult to use it because it presses random buttons and sometimes freezes until I turn it off and back on. PLEASE HELP.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
@anadelmar first do not turn on your phone, charge it or try to connect it in any way. Remove the battery as soon as possible from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points are still pertinent to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
Once it is properly cleaned, replace the battery and reassemble your phone. then you can properly troubleshoot.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 1
添加一条评论
If you open up the backing and let the motherboard dry it may help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ana DelMar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 2,088
