跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
iPhone 5c charging only with iPad adapter
Hello. I have problem with iPhone 5c doesent detect normal iPhone charger or computer. It doesen't show bolt symbol when charging with iPhone adapter. I have tested charging current and it is only 0.11A and it charging so slowly it takes days to full charge. But with iPad adapter the amp current is about 0.80A and it charging with it. Now I have replaced Tristar three times but still not normal current with iPhone adapter, it still gives the same 0.11A and with iPad adabter it still works nice. Can somebody tell what there is going on and what I should chek next. Any help would be really appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@inspiraattori you did not tell us if you replaced the iPhone charger. If your phone pulls 0.11A from that charger but 0.8A from the iPad charger I'd be looking at the charger not the phone.
这个答案有帮助吗?
得分 1
5条评论:
Thank you for your answer. Sorry I forgot to tell that I have tested it with many different iPhone chargers (working) and cables, and still the same 0.11A. And today I tested iPad adapter and it charging just fine with it.
完成的
...and with iPad adapter the bolt symbol appear as well in that iPhone 5c.
完成的
@inspiraattori only thing I try different at this time is a new battery.
完成的
@oldturkey03 I just replaced the battery with known good battery and still same situation, no bolt symbol and no charging :/
完成的
You should be pulling more than 0.8A, unless the battery is mostly charged. Have you tried replacing the Dock Flex? Also, Tristar (U2) isn't the charging IC.It serves to communicate with attached peripherals. So if you phone is charging and is recognized by iTunes, then Tristar is working properly.
Charging is handled by the PMIC (U7) so I would start probing that area to see if anything is wrong.
完成的
添加一条评论
Please change u2 ic
i hope your Problem Solved 100%
这个答案有帮助吗?
得分 0
1条评论:
Hello and thanks for your message. I've already replaced that tristar three times in that iPhone 5c without any luck. Still same amp current.
完成的
添加一条评论
添加你的答案
Mobilefi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 118
