跳转到主内容
加入维修社区 - 创建账户
BLU Vivo XL 于 2016 年 1 月发布,是 BLU 智能手机预算系列的一部分。
Phone won't turn on
My Blu Vivo XL phone's battery died and won't turn on. It has been plugged in but still nothing. I connected it to my laptop as a USB but all I can hear is the sound of a device connecting and disconnecting.
I attempted to hard factory reset it however, it made a small beeping/vibration sound and a white/greenish line flashed across the screen in the space of a second.
How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The connecting/disconnecting sound usually indicates that you either 1. have a bad charging cord, or 2. the charging port on your phone has come loose.
First, try a new charging cord, and see if this solves the problem. Note that when a battery goes completely dead, it can take some time (up to 15-30 min). I also suggest plugging the phone into an electrical outlet instead of using the USB port on your laptop.
Second, if after charging for an hour with the new cord in a wall electrical outlet doesn't work, slightly wiggle the cord in the charging port of the phone. Can you see the port moving? Does the phone seem to charge when you move the cord and hold it in a particular location/direction? If so, the solder joints of your charging port have cracked. You have two choices: 1. find someone to repair the phone (either micro-soldering the port or replacing the entire PCB assembly), or 2. replace the phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chrisan Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 2,135
