跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
How do you fix the screen crease after replacing the screen?
iPhone 7 was broken and purchased a new LCD screen replacement part online. Before install the screen, I tested the screen and it works normal, but after assembling the screen and turn on the phone, there is a bruise on the screen . Why does this happen and should I pay more attention to some place when install the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Kaye. Do you mean something like what is shown in this question What is causing screen issue after iPhone 5s battery replacement?
If so, then those are pressure marks. That means something isn't sitting right underneath the screen and it applies pressure against the LCD when you press.
Go back through the screen replacement guide and check to make sure everything is in place.
这个答案有帮助吗?
得分 3
2条评论:
I should add a mark that doesn't go away will likely need a new screen.
完成的
@danj good point. If the OP gets back to us with more detail (or pictures), we'll be able to tell if the damage is temporary or not.
完成的
添加一条评论
添加你的答案
Kaye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 300
