跳转到主内容
加入维修社区 - 创建账户
针对第 5 代 Honda Accord 双门轿跑车、轿车和旅行车的维修指南与支持。
Speedometer works when it wants
speedometer works when it wants RPM gauge works just fine. could the wires on the sensor be loose? Where is the sensor located? 1995 Honda Accord 5 speed thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Best bet is to replace the speed sensor . You need to remove the air cleaner and look down on the back side of the motor where the motor meets the gearbox . Under the distributer and the water hoses on the gearbox
http://breebamboo.ipage.com/archive/imag...
Hope this helps
这个答案有帮助吗?
得分 4
1条评论:
Is this in the same location for a 95 Accord LX, Automatic 2.2L?
由完成的
添加一条评论
There's a good chance your speed sensor is going bad, specifically the speed control sensor. I had the same issue in mine. So...what Jimfixer up there said
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barbara Edgman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,677
