跳转到主内容
加入维修社区 - 创建账户
15.6 英寸,Intel HD 核芯显卡,Core i3 2330M 处理器,Windows 7 家庭高级版 64 位,4 GB 内存,500 GB 硬盘
My system is dead
My system is not turn on like it is dead.
Don't know what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Never give up! What exactly happened? Did it randomly shut down? Where you using it? How was the battery and do you think the power adapter is working?
由完成的
You have to check a lot of stuff before you can presume that your screen is the cause of the problem.
1. You have to check if your power cable is working. If the computer is charging you can then go for option 2.
2. You have to see if the computer is turning on then failing. If this is the case. Then it may not be your screen but your computer that has crashed.
由完成的
添加一条评论
1个答案
最有帮助的答案
This could be a lot of things. Start by removing the battery, if it is detachable, and try to power up with the ac adapter. The blue light on the end of the ac adapter should light up Blue if the ac adapter is good. If that doesn't work then put the battery back in and remove the ac adapter and try to boot. If neither of these boot attempts work then the problem is the mother board. You should contact Dell tech support to find out if the laptop is under warranty, usually 1 year unless there is a warranty extension.
If you get either a series of beeps or the Power, Battery and WIFI LEDs blink in a pattern then let us know so we can decode the error.
这个答案有帮助吗?
得分 2
1条评论:
I have checked all this but suddenly my laptop started last evening and working fine and also I diagnosed my system by pressing F12 while power on and checked the system and it shows that there is no error at all and all parts working fine but todey in the morning again my laptop is not starting and still in sleep with sleep indication light is on.
由完成的
添加一条评论
添加你的答案
ABHISHEK JAISWAL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 609
